Sponsored by: CARiD
How to unarm the alarm with out the remote?
Old Dec 13, 2006 | 03:40 AM
BMWLR's Avatar
Default How to unarm the alarm with out the remote?
Do LR alarm system have a push-switch to disarm the alarm? I am comparing it with some after market alarms were the installer mounts a push botton to de-activate the alarm incase of a lost remote.
My Disco's alarm is acting-up and sometimes it activates by itself... my new remote is not programed yet.
Thanks
Old Dec 13, 2006 | 05:25 AM
Spyderman's Avatar
Default RE: How to unarm the alarm with out the remote?
No push button. My Disco II you can disarm the alarm by entering the code using turns in each direction using the key in the ignition.
Old Dec 13, 2006 | 11:22 AM
Ed, Rovers can disarm the alarm with the key or the remote, there are no hidden switches from the factory.
Are you having a problem with your's?
Mike
Old Dec 13, 2006 | 12:38 PM
BMWLR's Avatar
ORIGINAL: Spyderman
...by entering the code using turns in each direction using the key in the ignition.
Your post was not clear to me... hmm... is this like turning on and off the ignition switch on a specific sequence?
Thanks
Old Dec 13, 2006 | 12:52 PM
BMWLR's Avatar
ORIGINAL: Disco Mike
Mike
Hi DiscoMike, yeah... thats right... now you remind me that... I have taken out the driver's door switch/actuator to test it "outside its shell" thinking that this was causing my alarm problem. Well, it tested well and I have being lazy to put it back on.
And to answer your question, yes... my alarm activates by itself off and on and at random times. It has not worked for ~5 months but two weeks ago it started showing me again who is the boss!! I have posted questions and i have checked the switch on the hood, I checked the module connections, I was told Disco I does not have a spider, I checked the grounds and still... it has a mind of its own.
Cheers
Old Dec 13, 2006 | 06:26 PM
Spyderman's Avatar
ORIGINAL: BMWLR
ORIGINAL: Spyderman
Thanks
That's right, exactly as you describe. How to do it is described in the owners manual and the code should have been supplied to you in documentation.
Old Dec 14, 2006 | 03:09 AM
BMWLR's Avatar
ORIGINAL: Spyderman
Can some one else confirm if this is also true for a Disco I?
I'm not the first owner so I was not supplied with doumentation on such code. The previous owner confirmed not having knowledge of the code. I guess if this is true on Disco I, I would have to go to the dealership with my title and DL... but my nearest LR dealership is after 2 hour drive. Does any one on this forum work at the dealership
Old Dec 14, 2006 | 05:10 AM
Spyderman's Avatar
Sorry Matey, can't confirm if it's the same for Disco I as it is for II. Can't you phone the Dealer and ask? The Dealer that supplied the car originally should have the code on file.
RROJ
Oct 9, 2010 07:39 AM
RROJ
Oct 8, 2010 09:56 PM
phuzzzed
Feb 6, 2007 11:37 PM
eweaver
Mar 27, 2006 08:11 AM
