Sponsored by: CARiD
I have a problem with the temp gauge
Old Nov 7, 2012 | 06:56 PM
axelbeteta's Avatar
5th Gear
Default I have a problem with the temp gauge
I have a land rover defender td5 2004, I changed the ECU, now I have a problem with the temp gauge, it reads that is at middle temperature when is cold, and it reads cold when should be at the middle. What should I do?
Old Nov 7, 2012 | 08:08 PM
Did you use the same year ECU?
It has to be a ECU program problem.
Old Nov 7, 2012 | 11:34 PM
There is also a variation on ECU for petrol vs diesel; the heat signal to the gauge comes out on different pins. One work around might be to use a scanner or Ultra Gauge ($70 US) to read the live OBDII data for coolant temp. Schematic from RAVE attached.
File Type: pdf
Old Nov 8, 2012 | 06:17 AM
axelbeteta's Avatar
5th Gear
Default diesel engiene
It is a diesel engiene. I bought the ECU, was supposed to be the same year and for a diesel engiene.
Old Nov 8, 2012 | 06:40 AM
Also may want to check the wiring to the sensor, the gauge will act strange if sensor wire broken or grounded (pinched wire harness). The diesel and the petrol suffer the same design limit, in that "old school" Rovers used a separate sensor to move the gauge, newer ones use a single sensor, the ECU reads it, the ECU uses that data for various purposes, and the ECU sends a modulated signal to keep the gauge at center position most of the time when warmed up. Instead of creeping up every week as conditions change in the cooling system, the ECU waits until you are almost fried and then pops up the gauge. A scanner will tell you what temp is at a cold start, which shold be close to ambient in your parking area. If I unplug my sensor, the ECU reads it as -40F, and that is what is shown on the OBDII port. I guess you could also have a bad temp sensor.
The specs for the sensor used with the Bosch ECU are:
Motronic
• NTC type sensor (goes lower in ohms as temp increases)
• Sensor contains two elements, only one is used on Discovery, on Range Rover one is also used for the instrument temperature gauge.
• Output = Approx. 4.9v at -50°C (-58°F) to 0.75v at 130°C (266°F). Approx. 1.8v at 70°C (158°F)
• ECM fault default value = dependant on software map up to 60°C (140°F), after which Fuel System Inputs defaults to 85°C (185°F)
• Located at the top front of the engine, to the right of the alternator and in front of the plenum chamber.
Attached Thumbnails I have a problem with the temp gauge-pittsburgh-20120905-00034.jpg
Old Dec 13, 2012 | 07:33 AM
axelbeteta's Avatar
5th Gear
My defender is 2004 td5, I bought a used ECU but I do not know nothing about it . I was thinking in buying another temperature gauge, but what type do I have to buy?
Old Dec 13, 2012 | 07:41 AM
axelbeteta's Avatar
5th Gear
Default Temperature gauge working backwards
I have a 2004 td5 defender, I just change the ECU, after that the temperature gauge is working backwards, when the engine is cold the gauge is at the middle, when the engine is hot the gauge marks it is cold. I went to land rover Guatemala and they could not fix the problem, now I am thinking to buy another gauge temperature but do not know what to buy.
Old Dec 13, 2012 | 07:12 PM
Can you post a pic of the temp gauge?
We have almost no Defenders here in the US.
And no '04 Defenders for sure.
Old Dec 13, 2012 | 07:27 PM
Here's diagram for a 2002 Defender, there is a slight difference in wiring on a TDI vs a TD5.
File Type: pdf
Old Dec 15, 2012 | 07:00 AM
axelbeteta's Avatar
5th Gear
Default temperature gauge working backwards
I talked to the person who sold me the ECU to find out from what year was the ECU, It is from a 2,000 Defender, and my defender is 2004
