Sponsored by: CARiD
iCarsoft LR II - Stopped Communicating
Old Jul 23, 2017 | 12:00 PM
Friday Night Disco's Avatar
Default iCarsoft LR II - Stopped Communicating
Anyone has thoughts on why my iCarsoft LR II stopped talking to my Land Rover?
It worked just fine about a week ago when I was checking coolant temps. Now, it makes an attempt to talk to the ECU and I keep getting the no communications error. Retried multiple times and even tried it on another vehicle. Still no luck...
My first thought was bad cable but, not sure how to validate it.
I will call their customer support for feedback but, I thought it was odd that it just stopped communicating for no reason.
Old Jul 23, 2017 | 01:46 PM
mollusc's Avatar
You might try re-updating the firmware using the SD card. Maybe that will reset it.
Old Jul 23, 2017 | 01:54 PM
i will give that a try and report back
Old Jul 23, 2017 | 02:55 PM
Update didn't work...going to try their tech support
Old Jul 23, 2017 | 06:24 PM
number9's Avatar
Check fuse that powers the D2's port and or for 12vdc from pin? to gnd.
Old Jul 23, 2017 | 08:04 PM
No Doubt's Avatar
Disconnect your main 12v battery for 15 minutes then retry. Also, there is a note in the workshop manual that its BCU or ECM computer can only be programmed 16 times, so if you used up your last try, well...
Old Jul 23, 2017 | 08:44 PM
No bad fuses
iCarsoft didn't work on other vehicle either
Old Jul 23, 2017 | 09:15 PM
mollusc's Avatar
Originally Posted by Friday Night Disco
No bad fuses
Not to point to the obvious, but you checked to make sure the cable is securely plugged in to the unit?
Failing that, tech support seems like the only option.
Old Jul 23, 2017 | 09:36 PM
i did check the cable, was even thinking about checking each pin with a multimeter
Old Jul 25, 2017 | 09:46 PM
Tech support number is disconnected
email to to tech support unanswered
i will check the pins for loss of connectivity and will consider the product licensed by AB as a replacement
