Sponsored by: CARiD
idle question
Old May 20, 2008 | 07:36 PM
roving patrol's Avatar
Default idle question
What is the best/advisable idle on a Discovery 1997? Will lower idle save on gas and engine performance?
Old May 20, 2008 | 08:27 PM
lrobin3w's Avatar
Default RE: idle question
There is a specified adjustment for the base idle on your disco, It is 18 to 20 steps as measured when idling at full operating temp. I only know how to adjust this using the dealer supplied testbook equipment. Idont know how to adjustit using other methods!
Old May 21, 2008 | 07:53 AM
If your truck has an automatic tranny, your idle should be around 700 to 750 in gear at operating temp with the a/c off.
Leave your idle alone, you won't improve you MPG by lowering it.
What sort of MPG are you getting and what have you done to improve it?
Old May 22, 2008 | 12:37 PM
I guess my idle is just normal then cause it is just between the 700-750 mark in gear. Mike, the only thing I do to improve my mpg is make sure that I have the recommender psi in my tires! Would that be enough or is there anything more I could do to improve my mpg?
Thanks
Old May 22, 2008 | 01:37 PM
Start looking at tune related stuff, including plugs, Magnacore wires, crank case flush, an induction cleaning and burn high octane.
wick_60010
Nov 22, 2017 04:25 AM
KGN96discoSE7
Sep 23, 2017 07:23 AM
NYDISCO
Aug 19, 2008 08:32 AM
don_r6
Aug 28, 2007 04:09 PM
westernsun
May 27, 2006 04:24 PM
