Sponsored by: CARiD
Initial failure to start disco 5
Old Oct 22, 2024 | 06:53 AM
Dentaldave's Avatar
Default Initial failure to start disco 5
Twice I have been refuelling my V6 2018 Discovery with 93k miles on the clock and when I press the start button I hear a faint click of a relay but nothing else.
I can lock the car but the hazard lights will not switch on either.
After a few minutes of attempts the tft screen will illuminate, the two dials flick over to max and return to zero and extinguish . The centre screen does not work at this point. A while later the centre screen will illuminate on my attempts and finally the engine will start.
The key has a good battery and when it starts the engine turns over at the normal speed.
It then performs perfectly normally until presumably the next time! The problem is that it is entirely random the only common denominator so far is at a fuel station.
There is nothing shows up on my diagnostic as a fault.
Very annoying when at a fuel station with vehicles waiting in line behind me as can be imagined.
Appreciate your help here.
I am in the UK
Old Oct 24, 2024 | 01:50 AM
Elzot's Avatar
Sounds like what happened to me when my battery was very low. Have you checked alternator output? Maybe a bad ground?
Old Oct 24, 2024 | 03:58 AM
Dentaldave's Avatar
thanks for your suggestion. When the car does start eventually the engine turns over as fast as ever so I’ve no concerns re the alternator. These Discoveries also warn if the battery is low and it never has.
sacharama
Dec 13, 2022 04:18 PM
landed.gentry
Oct 31, 2022 07:09 PM
shaneyb2
Nov 29, 2021 10:26 AM
tanman1234
Sep 24, 2021 10:34 AM
Tristan Stumpf
Jan 11, 2020 06:40 PM
