Sponsored by: CARiD
Intake air temperature error ?
Old Jun 15, 2024 | 10:40 AM
Freelandy12's Avatar
New Member
Default Intake air temperature error ?
I am new to the forum, my first post, hoping someone here can help with this issue.
2012 Freelander 2.2 diesel.
getting the P007A-17 error code as permanent, the charge air cooler temperature circuit, which I am assuming means the IAT sensor is knackered.
my issue is where is the sensor?
it’s not in my throttle body, the usual location is blanked- see photo.
I have a 4 wire MAF, some say the IAT is integrated in the MAF. I have been advised replacement is a. OS H part No. 0 986 280 700.
there is also a sensor in the inlet to the intercooler, it’s a Volvo branded part no 0 261 230 296, BOSCH equiv is 0 261 230 295. Depending on where you google this is described as a pressure sensor, a temperature sensor and some placed as a combined pressure/ temp sensor. My Volvo sensor only has 2 wires in the harness, so I am assuming it’s either a pressure or a temp sensor, but not both, as there are only 2 wires in the harness.
my chassis no is H282371. UK car.
appreciate guidance as to where the IAT is on this vehicle.
thanks in advance!
Volvo branded pressure/ temp sensor?
Blanked throttle body - usual location of IAT
MAF with 4 wires
ginacarpenter
Apr 2, 2023 10:59 PM
halloween rover
Sep 9, 2021 01:48 PM
dustinkantu
Oct 2, 2016 10:32 PM
Dimitri_g101
Freelander
Feb 5, 2010 01:07 PM
wielgoshoff
Engine & Internal
Mar 18, 2008 11:37 AM
