Sponsored by: CARiD
Key gets stuck in ignition
Old Nov 1, 2008 | 02:12 PM
Kraftyz51's Avatar
Default Key gets stuck in ignition
I have read through all the posts and no one has the same symptoms. Truck runs great but yesterday when I parked the truck at home the key turned to the pullout positionbut would not come out of the ignition. I am able to crank the truck no problem ufortunately I will have battery drain if I do not pull they key out. I figured it must be electrical because I have to disconnect the battery, pull the key out then reattach the terminals. I do not want todo this everytime especially in the Chicago winters.PLease help.
Thanks
Old Nov 2, 2008 | 07:12 AM
hazletbassist89's Avatar
Default RE: Key gets stuck in ignition
Next time it happens try shifting out of and back into park, sometimes something doesn't catch right, and even though you're in park, the ignition still thinks you're in gear and won't let you remove the key. Happens to me occasionally.
Old Nov 2, 2008 | 11:46 PM
Kraftyz51's Avatar
Thanks for the reply. I figured it out early the next morning. Shifter was not all the way forward.
Thanks!
ImQuattro
May 1, 2014 08:36 PM
We-go-up
Mar 26, 2014 05:44 PM
will rocket
Off Topic
Sep 12, 2013 06:23 AM
jycsalas
Aug 3, 2009 04:27 PM
Tayo
Sep 10, 2005 01:13 AM
