Key Ignition Problem have tried this please help
Hey you guys, I really need help.
I am having the aforementioned problem.
Firstly, I took the cap off the gearshift to attempt to tighten bolt, though I did not see one
And then I took off the steering column in attempt to remove ignition solenoid, but I do not have a right angle screw driver.
landrover key stuck. in the ignition - YouTube
I really need to get to work tomorrow and any help is monsterly appreciated.
If you're looking to tighten the 3/4" nut on the shifter you need to remove the clip on top in your photo. Then pull out the plunger for changing gears. Then you will see the nut. It's usually only finger tight anyway. Get a deep socket and you should be set with tightening that nut.
I don't see how removing or tightening this nut is going to solve your problem if it's the same problem the guy had in the video. Am I missing something?
Thank you for your response.
Well there are multiple reasons why the key might not release from the ignition. According to a member of this forum, 98% likelihood on older discovery models is that the gearshift is not registering park. The remedy is to remove the top of the shifter and then tighten a bolt per photo one.
If this options fails, then the video is basically the work-around for disengaging the ignition lock all together; thusly the key can be removed from ignition cylinder in any gear.
Tomorrow I will try pulling the plunger up and then looking for the bolt.. You wouldn't happen to have a picture would you? I have scoured the internets.
Thank you.
Thank you.
Cowtown1411
05-01-2012 09:37 PM
zracin
07-31-2011 03:43 PM
