Sponsored by: CARiD
Land Rover Disco V8i ES Transmission Fault
Old Sep 15, 2010 | 09:27 AM
Mac404's Avatar
3rd Gear
Exclamation Land Rover Disco V8i ES Transmission Fault
Hello all,
I own an R registration Land Rover Disco V8i ES. It has an automatic 5 speed gear box. Recently the Disco broke down with the following issues:
Gear stick moves normally through the box with no noise
Engine Sounds like a Land Rover
Idles normally
No power to wheels (no forward or reverse motion when in gear)
I am seeking an idea on what could be the potential issues i.e. Gear Box, Drive Shaft, Gear Linkage etc?
Please Help
Mac
Old Sep 15, 2010 | 11:19 AM
XCELLER8's Avatar
Cool
Check the shift cable linkage....it's pretty easy to see from under the truck, start with that and let us know what you find.
Old Sep 16, 2010 | 03:28 AM
Mac404's Avatar
3rd Gear
Thanks XCELLER8,
I will check it out after work tonight...
Mac
Old Sep 16, 2010 | 08:53 AM
Better start with the basics cause r=Rover didn't make a 5 sp automatic, what year, model and mileage on your truck? Is your check engine light on, if so what are the 4 digit fault code numbers?
Old Sep 16, 2010 | 12:36 PM
Mac404's Avatar
3rd Gear
Post
Sorry my mistake not sure why I wrote "5 speed"
Year is 1998 and it is a V8i ES Disco with 130000 Miles
No engine management lights by the way. Going to check the cable linkage tonight.
Thanks
Mac
Last edited by Mac404; Sep 16, 2010 at 12:38 PM. Reason: Forgot to mention mileage
Old Sep 16, 2010 | 12:45 PM
There is no cable linkage for the shifting of a 5 sp.
Start over and give us more specific information so we can help you.
Old Sep 16, 2010 | 08:01 PM
Mac, make sure the transfer case did not slip into neutral by accident.
cat175
Jul 10, 2022 07:07 PM
06Range
May 8, 2013 09:01 PM
lennos
Nov 3, 2009 06:16 PM
caseymackenzie
Aug 23, 2006 12:08 AM
