Sponsored by: CARiD
Land Rover II Trim
Old Apr 19, 2011 | 06:59 PM
harryashley's Avatar
7th Gear
Default Land Rover II Trim
Hi All,
Would appreciate if someone could tell me how to remove the plastic trim on the pillar posts (exterior) on the 2001 Discovery, in plain English would be much appreciated.
Thanks in advance
Harry
Old Apr 19, 2011 | 07:09 PM
I have no idea.
Old Apr 19, 2011 | 07:17 PM
photocrimes's Avatar
Take the plastic rivets out, three on each side. Pull the push pins in the center out and then the rest of the rivet will pop out. Then carefully start at the top where it contacts the wind screen and pull it away from the glass. You will need to pull up while gently pushing in on the curved surface. It will pop loose. There are three metal connectors that attach it to the body. The plastic trim will pop out of these. One at the top and bottom, one in the center.
Install in the reverse order. Putting them back on is 10x the fun! Once you get the hang of it, its a breeze.
Old Apr 20, 2011 | 08:59 AM
7th Gear
Default Trim
Thank you very much for that, I apologies, I should have said that it was the C Pillar (behind the rear window) that I was asking about.
Thanks in advance
xhevi
Jan 17, 2019 01:31 PM
goatman
Jan 12, 2013 10:08 AM
importtek
Nov 24, 2009 05:35 PM
Tom Sederburg
Nov 7, 2009 12:13 AM
the_infamous
14
Oct 21, 2009 09:47 PM
