Land rover range rover 1996 HELP?
I just purchased a 1996 land rover range rover hse 4.6 the wonderful person i bought from had took a cutting torch heated up the springs to drop it to the ground and i need to find just the coil springs without airbbags to put on it is there anywhere i can but used parts for this thing and it not cost a goldmine there are some other small parts i need as well thanks for any help
If it's got coils, it's been converted. I don't think any 96+ range rovers came with coil springs.
Kit: Range Rover Coil Spring Conversion Kit # 9520LB | Range Rover Suspension Parts
front spring: Spring - Coil - Front (White Stripe) (8002 Same Fit As Part # FRT COIL SPRING) - Land Rover springs from Atlantic British
rear spring: Spring - Coil - Rear (8004 Same Fit As Part # REAR SPRING) - Land Rover springs from Atlantic British
mauemiliani
12-06-2005 05:04 PM
