Leak at "coolant" flange
I have a leak at what seems to be called a coolant flange near where one of the hoses is connected. Assume it is cracked as it is plastic. Attached is a picture of what I found online that they claim to sell for roughly $55.00. Does that make sense? Also, is this something I do myself or send to the shop. If they sell the entire assembly as they claim, I would only have one or two difficult access clamps to remove.
You can do it yourself. You should flush the coolant system at the same time. The P/H for the hose is PEH000080. It is the thermostat to water pump hose. It comes as one piece. Prices and quality vary...
http://www.bputah.com/Disco2%20Parts...PEH000080.html
Make sure you follow the bleed procedure in the RAVE.
ZMonet
06-24-2016 04:00 PM
