Sponsored by: CARiD
Leak at "coolant" flange
Old Apr 21, 2015 | 03:03 PM
MichaelDisc02's Avatar
7th Gear
Default Leak at "coolant" flange
I have a leak at what seems to be called a coolant flange near where one of the hoses is connected. Assume it is cracked as it is plastic. Attached is a picture of what I found online that they claim to sell for roughly $55.00. Does that make sense? Also, is this something I do myself or send to the shop. If they sell the entire assembly as they claim, I would only have one or two difficult access clamps to remove.
Old Apr 22, 2015 | 08:39 AM
acamato's Avatar
You can do it yourself. You should flush the coolant system at the same time. The P/H for the hose is PEH000080. It is the thermostat to water pump hose. It comes as one piece. Prices and quality vary...
http://www.bputah.com/Disco2%20Parts...PEH000080.html
Make sure you follow the bleed procedure in the RAVE.
Old Apr 22, 2015 | 09:33 AM
drowssap's Avatar
it would hurt to order a 180 thermostat from them at the same time
Old Apr 22, 2015 | 10:53 AM
7th Gear
Thanks for the advice to all. I will go at it myself...
MJ
jycsalas
May 23, 2019 03:02 PM
ZMonet
Jun 24, 2016 04:00 PM
meltdowndave
Jun 22, 2008 06:25 PM
Chrisinhouston
Dec 23, 2007 10:26 AM
sixeleven
May 21, 2007 09:30 PM
