Sponsored by: CARiD
leaking anti freez
Old Apr 3, 2007 | 10:55 AM
jshooter535's Avatar
6th Gear
Default RE: leaking anti freez
at the machine shop they have ways of testing it for cracks and everything just ask them to run the test for you
Old Apr 4, 2007 | 02:37 AM
Bulldogs_1789's Avatar
4wd High
i had the same thing happen to mine a few months ago. turned out it was the plate on the front of the throttle body. mite want to have someone take a look at it...and definatly get the pressure test done.
Old Apr 4, 2007 | 07:37 PM
El Jefe's Avatar
well. just got the head back from the machine shop. did a crack check, a volume check and checked for flatness. no cracks, but was warped bout 3 thousandth. so i had them mill it down. looks all purty now. so i gets to put it all back together and see. i know it was leaking from the head to block mounting surface. hopefully the warpness was it. thanks again for all your help.
Old Apr 8, 2007 | 10:16 PM
El Jefe's Avatar
hey jshooter, how much you charge for fixin that problem?
Old Apr 9, 2007 | 09:14 PM
El Jefe's Avatar
what are the torque settings for the the head and the intake manifold?
Old Apr 12, 2007 | 04:44 PM
mhimself's Avatar
6th Gear
Did you check your heater core o rings? Should be two aluminum pipes running thru firewall to heater core o rings go bad and fills floor with anti freeze mostly on passenger side though unless heater core has gone bad completely. Or maybe just warped head. I have a 99 RR and just replaced my o rings problem gone. Good Luck
Old Apr 12, 2007 | 05:45 PM
okdiscoguy's Avatar
ORIGINAL: El Jefe
i'm going out to check for warpness right now. my dad has a friend that works at a machine shop that will mill it for me. I am really gonna check closley for cracks too. I live in Ogden UT. thats bout 45 miles north of Salt Lake. if I need a head, I'll let ya know. hey, did you guys know Rovers are expensive to fix?
What? Rovers expensive to fix? naaaaah....
Old Apr 27, 2007 | 12:28 AM
6th Gear
the shop that i work at usually charges 1700.00 and we have everything there... the torque settings i can get for you i dont have to access my comp it's at work and i am on vacation gimme a week
rally1
Feb 22, 2022 06:22 AM
brent
Oct 17, 2006 11:36 AM
dikubec
Jul 28, 2006 05:22 PM
37chambers
Aug 22, 2005 10:40 PM
golfpro
Oct 21, 2004 01:52 AM
