Sponsored by: CARiD
Leaking sunroof
Old Feb 14, 2010 | 08:14 PM
geoffthepoolguy's Avatar
Default Leaking sunroof
Has anyone had any experience in repairing a leaky sunroof? My '96 Disco has 2 factory sunroofs (both electric) and the rear one is leaking. Any recommendations?
Old Feb 15, 2010 | 03:14 PM
hilltoppersx's Avatar
does it open and close? they are always electric. it can be a few things you need to see if the sunroof is still on rails and is closing properly, you need to check the drains there are two drains for each sunroof that can be accessed be removing the headliner.
Old Feb 15, 2010 | 05:55 PM
magnum mark's Avatar
Hi, Are you sure its your sunroof and not your roof bars. I had same problem and it turned out to be the foam around the roof bars.
Old Feb 19, 2010 | 04:28 PM
Hey thanks for the advice. I spent a few minutes poking around and found the screws that hold the glass to the open/close mechanism were loose. This caused the glass to lose contact with the gasket when it was closed resulting in a leak. I tightened up the screws and ran a garden hose on it and it stayed dry. It still gets stuck in the fully open position but in February I'll leave it closed anyway.
rally1
Feb 22, 2022 06:22 AM
Spencerfitch
Jun 4, 2010 03:39 PM
kseasley
May 3, 2010 06:45 PM
Kent Green
Nov 5, 2008 04:30 PM
crainface
Oct 29, 2008 06:25 AM
