Lifter ticking..
Try a good 15w-40 oil like shell rotella, but most likely , if your'e convinced the noise is coming from the valve-train. it's probably a worn rocker arm and/or rocker shaft. I chased a tick for a while before I found a rocker arm that the steel insert for the pushrod had loosened up and made the racket only after the engine had warmed up.
john65b
10-10-2013 05:00 PM
