Lifter ticking..
If got a terrible ticking noise coming from the engine and i am determined that its a lifter problem. How much is this gonna cost to fix and how crtical is it that i get it fixed a.s.a.p? Thanks
You need to change oil, 10w-30 is to thin for these engines, especially during the warm weather.
I use and swear by Shell Rotella 15w-40.
Try that and see what happens, worse case you're out the cost of a oil change.
Try a good 15w-40 oil like shell rotella, but most likely , if your'e convinced the noise is coming from the valve-train. it's probably a worn rocker arm and/or rocker shaft. I chased a tick for a while before I found a rocker arm that the steel insert for the pushrod had loosened up and made the racket only after the engine had warmed up.
I agree, go with a heavier oil, not to fix the tick but because the engine needs it.
As for your tick, go to the D2 section, look at a sticky I posted for valve train noise, read it, then send me your number and lets talk.
john65b
Oct 10, 2013 05:00 PM
