Sponsored by: CARiD
little help please
Old Apr 12, 2011 | 04:31 PM
irishlandie's Avatar
3rd Gear
Default little help please
my defender is eating batteries put in a new one last night dead by this morning any ideas guys
Old Apr 12, 2011 | 04:36 PM
3rd Gear
oh ya sorry its a 98 300tdi
Old Apr 12, 2011 | 07:01 PM
hilltoppersx's Avatar
Sounds like an electrical drain. Do you have an OHM meter?
Old Apr 12, 2011 | 08:18 PM
You have something that is on or a bad ground.
I am assuming that you fully charged the battery before you put it in the truck.
Old Apr 13, 2011 | 06:00 AM
drowssap's Avatar
put a test light between the negative battery terminal and the cable end, it should light if there is a draw. Now start pulling fuses one by one until the light goes out, when the light goes out; now you know what curciut is causing the draw. Now put the fuse back in, and disconnect each thing on that curcuit until the light goes out again, when it does you know know what is causing the draw, I think you can take it from there. good luck
Old Apr 13, 2011 | 12:52 PM
Chris-bob's Avatar
Actually, it is usually better to pull all the fuses first, then put in the test light. That is because you can get a draw from several places. Not just one.
saltyrover
Apr 25, 2013 06:44 PM
Rover_Hokie
Sep 27, 2012 04:42 PM
Murph9265
May 7, 2012 04:07 AM
Jasondizzyd
Jan 18, 2009 10:23 PM
NCBurger
May 19, 2008 08:29 AM
