Sponsored by: CARiD
Please Help If you Can :)
Old Apr 12, 2011 | 04:21 PM
brennan711's Avatar
3rd Gear
Unhappy Please Help If you Can :)
I am a first time Land Rover owner, and I am very excited. Unfortunatly my excitement was interupted by several lights that started coming on on my dash. (2001 Land Rover Discovery II SE)
Check engine light came on and when I ran codes it say:
po171 and po174... System to lean bank 1 & 2.
P 1175- DTC definitions not found! Please refer to owners manual.
p1172- ox sen too rich
Gear ratio error gear 3
Gear ratio error gear 4
Also, every once and a while 3 lights all come on at the same time, but eventually go off: traction control, abs brake, and hill decent.
My vehicle runs fine except when it's at idle and it sounds like it is running rich and a slight miss. The transmission doesn't jerk or miss a beat. If anyone can please tell me where I should start to try to fix my problem, it would be greatly appreciated.
Old Apr 12, 2011 | 08:17 PM
Here is what you need to do, use the search function on the forum, there are tons of info on the "3 Amigos".
Second, you need a tune up and maybe a MAF sensor.
If you go to the DII section you will find all the help you could ever want.
Old Apr 13, 2011 | 09:40 PM
brennan711's Avatar
3rd Gear
I am ordering a MAF sensor now, and I am going to start there. Thank you so much for the help, I am very grateful.
Old Apr 14, 2011 | 11:17 AM
Hope you ordered it from British Parts of Utah. If no hope you did not order a after market or generic MAF cause they usually will not work.
Old Apr 14, 2011 | 04:28 PM
brennan711's Avatar
3rd Gear
If it's a bosch MAF sensor with the same part number, it shouldn't really matter where I order it from... Correct?
Old Apr 14, 2011 | 05:57 PM
Chris-bob's Avatar
If it is OEM, then it doesn't matter where it comes from. If it is aftermarket, then you could have problems.
hamad ss
Jan 25, 2015 03:54 PM
calebbo
Oct 12, 2011 09:54 PM
chendricks207
Jan 11, 2010 03:21 PM
chendricks207
Jan 7, 2010 08:25 AM
MRDM1
Mar 16, 2007 07:03 PM
