Sponsored by: CARiD
Locked out of Discovery
Old Jan 14, 2008 | 12:30 AM
LockedOut's Avatar
5th Gear
Default Locked out of Discovery
All of a sudden, all at once, my doors do not open. Only the driver's door with the key. I can lock the driver's door with the key fob but when I press unlock, nothing. All doors are apparently superlocked. I tried the inertia switch, the hazards came on but the doors remained locked. Any other suggestions. I hate to go to the dealer!
Old Jan 14, 2008 | 08:05 AM
Default RE: Locked out of Discovery
Have you checked your fuses, have you tried resetting the alarm, by locking and unlocking the door slowly with the key, 3 times, what happens if you use your dash button to unlock the doors?
Old Jan 14, 2008 | 11:10 AM
LockedOut's Avatar
5th Gear
Thank you. I've check the fuses. They are good. I've tried numerous combinations with unlocking and locking with the key. I've tried the inertia switch. When I push the button on the dash, I get no response at all. The driver's lock locks with the key fob doesn't unlock. I have to use the key. No key entry for the other doors and no way to pull up the locks. THis is a 2002 Discovery by the way.
discovery2001
Dec 16, 2020 08:04 PM
clout98 disco
Aug 7, 2008 04:03 PM
LockedOut
Jan 14, 2008 11:40 AM
LockedOut
Jan 14, 2008 12:44 AM
