Sponsored by: CARiD
lopsided disco 2 2003 standard spec.
Old Jul 16, 2016 | 03:31 PM
static's Avatar
4th Gear
Default lopsided disco 2 2003 standard spec.
Hi guys,
I have a discovery 2 td5 2003 is all standard. Its new to me so as you can probably guess I am finding stuff that needs attention or changing. I have noticed that she is sitting lopsided leaning down on the drivers side, If i raise it up with the off road setting its still very noticeable that the drivers side is lower.
I had it at a Landrover specialist garage I am using now and they said that it was something to do with a sensor that they put a cable tie on as the rubber had split the last time it was in for a service, they said that it was to tight and stopped it from fully opening, apparently it was sorted now, but its just doest seem right still and its really annoying me. Apparently the air bags are fine no leaks at all so what do you guys make of this.
How hard is it to fit new sensors and would i need to hook it up to a computer ?
Any advice welcome guys and I hope this all make some sense to you.
Thanks.
77_scorp
Jul 26, 2016 10:08 PM
wastedincome
Oct 24, 2012 03:10 PM
crainb45
Jun 4, 2009 07:21 PM
Range Roguer
Sep 29, 2007 01:29 PM
juanpobre
Nov 17, 2006 04:06 AM
