Sponsored by: CARiD
loud chirping sound under acceleraltion
Old May 22, 2013 | 10:26 AM
You need to crawl under your truck with a flash light to verify that all 3 of the front u-joints have grease fittings. If they don't that shaft must be rebuilt or replaced, even if it is not causing your sound, because when it fails, and most of them do, it will destroy your tranny also.
Old May 22, 2013 | 02:30 PM
Charlie_V's Avatar
These senior members and on up know alot more than I do, but I can tell you that removing the (front) driveshaft is as simple as removing eight nuts.... slide it out, and take it to a driveshaft shop. Replacing the U Joints looks really hard if you don't have the right equipment (ie, a large press with the right fittings). I have seen it done on YouTube (using a vice and a socket and a big hammer), and decided to go to a shop. The U joints are cheap and if it is off the vehicle, the labor is too.
matt3502
Feb 17, 2013 05:29 PM
hubie
Nov 25, 2011 10:18 PM
01TXDisco
May 27, 2010 01:33 PM
Sfef84
Jul 14, 2008 05:59 PM
machinegunner
Sep 24, 2007 11:23 AM
