Sponsored by: CARiD
Low compression..no start Freelander
Old Jan 8, 2008 | 04:23 AM
Tim Meal's Avatar
Default Low compression..no start Freelander
Had head gasket replaced yesterday!However mechanic cannot get engine to start.He has checked timing,plugs,water leaks,sump...but can't get sufficient compression to start engine.He thinks its possibly because there is little or no oil going through the hydraulic tappets.Can anbody help?
Old Jan 8, 2008 | 07:25 AM
Default RE: Low compression..no start Freelander
That doesn't make since, is it throwing codes while trying to start?
Old Jan 8, 2008 | 08:42 AM
raid13's Avatar
has he used the factory tools to line up the camshaft cogs and
bottom end installing the timing belt? i think i would star there.
Old Jan 8, 2008 | 08:41 PM
sideburns's Avatar
factory tools and the correct procedure are essential,these are interference motors,if you don't have your ducks in a row kerblamo...bent valves,which means no compression...I wish you luck
Old Jan 9, 2008 | 08:50 PM
lrobin3w's Avatar
I have to agree with sideburns, there are 3 timing belts on the freelander v6 and they are nasty. even with fact tools.
Old Jan 10, 2008 | 12:05 AM
ajh's Avatar
ajh
Please tell us it's a dealer. Then which one.
zhirkhan
Aug 21, 2011 12:24 AM
UsualSuspects
Jun 20, 2011 09:47 AM
1stevereynolds
May 20, 2009 01:26 PM
MacRR
May 5, 2008 08:29 PM
dlkk
Sep 21, 2006 09:09 PM
