Metal bits in intake, low(er) compression on drivers side
Old Aug 20, 2011 | 08:19 PM
zhirkhan's Avatar
4th Gear
Default Metal bits in intake, low(er) compression on drivers side
1996 Disco 1, about 148k
So I'm planning on changing the leaky valve cover gaskets today and when I took the throttle body off there were several bits of steel and aluminum in amongst the stacks...bits of piston and rings I believe.
My big question is how the hell can a truck continue to run with this kind of damage? I bought this in February and have driven about 3k so far, there is some noise from the motor but nothing dramatic. (Besides the alternator bearings)
I got the compression tester out and one side of the motor is about 170-175 and the other side is 120-122psi. Obviously I have a serious problem somewhere but I'm just blown avay by the consistency...I was expecting a completely dead cylinder, not 4 sorta low ones.
I'm debating doing anything at this point other than getting rid of it, I swore I wasn't going to put a bunch of money in this truck.
Old Aug 20, 2011 | 08:36 PM
Any wierd color or "solder" on the spark plugs for that side? Does adding a tablespoon of oil to the cylinder bring up the pressure (rings?) of the test? Maybe you have one dead cylinder AND a bad HG. Or bad HG and metal from something else. Does listening to spots around the engine with a broom handle pressed against your ear narrow the noise to a certain area?
Old Aug 20, 2011 | 08:40 PM
atancreti's Avatar
If you don't want to put money in it, DRIVE HER TILL SHE QUITS ON YOU!!! C:
Old Aug 21, 2011 | 12:24 AM
pedronz's Avatar
you would be doing well the have bits of piston and ring up in the intake manifold and still have a motor that runs....
Pedronz
cosmiccharlie
Aug 12, 2020 01:42 PM
Jon Pitts
Jan 19, 2015 12:04 PM
freshdew82
Nov 7, 2012 10:07 PM
05gixxer
Aug 31, 2011 10:49 PM
adambarry
Mar 30, 2010 08:17 AM
