Sponsored by: CARiD
LR-2 lifting (jacking) points
Old Jul 20, 2009 | 09:14 PM
na011's Avatar
4th Gear
Default LR-2 lifting (jacking) points
Is there a way to jack up a LR-2, take all 4 wheels off and put it on four jack stands in order to change the brakes?
Old Jul 21, 2009 | 07:52 AM
Sure, jack up one wheel at a time, but why make so much extra work for your self?
Old Jul 22, 2009 | 02:20 AM
Greg Duncan's Avatar
Of course you can always do that to change the breaks. But don't you have any ramp with space between the tires so that you won't get tired jacking up then removing the tires? Just to add up, since your changing your breaks, have time also to check your engine. Check the valves if they are still intact and if there is a Valve Spring Locator on each of the valves. This is for you to prevent engine failure. Just for your appreciation dude!
Old Jul 22, 2009 | 05:34 PM
signals3_t5's Avatar
Nice Thoughts
good luck
Get more details
Old Jul 27, 2009 | 08:42 PM
na011's Avatar
4th Gear
Thumbs up LR-2 lifting (jacking) points & Brakes
Disco Mike was correct. Lifting one wheel at a time & putting on new rotors, pads & a flush worked fine. However the brake job was still a pain in the rear.
Tadpole
Feb 2, 2025 11:14 AM
OldSkoolFool
Feb 18, 2014 11:02 PM
apcollin
Aug 5, 2013 03:56 PM
shaggy52282
May 25, 2012 07:54 PM
tshah209
May 21, 2011 08:36 PM
