LR3 sitting on wheels, help!
My 05' LR3 is sitting on the wheels. I hadn't been to my truck in a few weeks and came up on it sitting so low it's sitting on one of the wheels. I thought maybe it had been some time past and once I would start the engine it would raise back up, but it didn't. The Suspension light is on AND the Adaptive Front Lighting System light... neither of which had been on ever before.
Could it be the battery, for both systems going out? Or is it just coincidence, and it's my Compressor and a fuse for the Adaptive Front Lighting System?
Please help!
Please help!
Questions regarding the Discovery 3/LR3 models should be posted in the LR3 section of the forum. That is where LR3 folks hang out and will be more likely to respond to your posts.
As for your issue, it may very well be the air compressor has gone bad. Or perhaps one or more of your air struts has failed. It is common for the air suspension system to develop problems such as leaks in the struts and compressor failures after several years of use or 100,000+ miles on wear. Get the truck charged up, turn it on and hook up a computer diagnostic device so you can read the air suspension system codes and pin point the problem. You can purchase a diagnostic device here: DIAGNOSTIC TOOL SCANNER II ICARSOFT - Rovers North - Classic Land Rover Parts
Atlantic British has a youtube channel with how to videos:
Air strut replacement on LR3 and Range Rover Sport
Air compressor location on LR3
ken21
Jan 2, 2014 05:58 PM
Kooner
Aug 28, 2007 04:51 PM
