Help needed asap....car sitting in a shop for 2 months !!!
Old Dec 28, 2013 | 11:05 AM
ken21's Avatar
6th Gear
Default Help needed asap....car sitting in a shop for 2 months !!!
Guys. I had a 4.2 supercharged 2005. One day i was in a stop-n-go traffic and notice stem coming from the bonnet and after 5 mins of " gentle " driving to a spot to park the car i notice it is leaking coolant. So callup a tow trunk and tow in back to a garage i know. That's happened last month.
So at first my mechanic told me he spotted 2 coolant - heater hoses that is leaking which i order and had it installed. Everything seems ok and the mechanic return the car for me which after 10mins of driving,coolant leaking all over the place again. So got tow back,and had them look at it again. This time they told me a outlet area on the radiator housing has cracked and causing the coolant to leak,fine than new radiator in. I told them to tested it before handing it over to me this time but again after 2 days,got a call from my mechanic saying that the car still over-heat,they now say my viscous fan that cool the radiator is not spinning and suspect the motor for the fan has died. So again new fan w/motor replaced,i thought this time everything should be fine. But again,installed the fan,tested it for a few times and the car over-heated again,so they're now saying something is not telling the fan to spin,i think both low and high speed is not working aswell or 99% of time both hi and lo will not come on,maybe very once in awhile,the high speed fan will turn on. (( Even the temp gauge close to redline,the high-speed won't turn on ). BTW,3 other coolant hose has replaced during this process,i'm not really suspecting either the mechanic don't know how to fix or check on this car and just told me to keep replacing parts which he THINK is not working or .......
Any idea guys ?? Had the car dropped off with them close to 2 months now and spent quite alot of money on replacing parts which i think some are not need. So any idea what i should ask them to look for ?? They run a scan and had a code : P0480 fan 1 control circult.
Right now the car drives fine,engine power,A/C and everything works. Mechanic can took it out for a test drive for 30mins still nothing happens,than all of the sudden the temp gauge climbs to the redline again. The fan is not running...maybe 1 time out of 10. So i'm planning to replace the coolant temp sensor aswell but another direction ?? And where is the fan control unit or motor's fuse and relay located at ?? Big Cry
Old Dec 29, 2013 | 04:14 AM
Have them do a test for exhaust gas in coolant again if not done already.
Old Dec 30, 2013 | 05:08 PM
tony1963's Avatar
Blown head gasket - motor toast - junk it.
Old Jan 1, 2014 | 05:00 PM
Rovin4life's Avatar
How about avoiding that mechanic since he can't diagnose anything. Take it to the dealr to see if its junk or not.
Old Jan 1, 2014 | 05:52 PM
LR Techniker's Avatar
I agree^^^^ Its time to get that thing out of there, its obvious the mechanic is in over his/her head.
If it were me, I would dispute some of the charges as well, since the condition of the vehicle has yet to change.
Old Jan 2, 2014 | 05:58 PM
tony1963's Avatar
You can dispute the charges until the moon turns orange but most state laws enforce a mechanic's lien. Being unable to diagnosis does not void the bill.
Frankly, it was YOUR MISTAKE to take it to an independent instead of the dealer. You own the decision.
DadsDiscoII
Apr 1, 2015 10:36 AM
Brazilian209
Apr 22, 2014 07:00 PM
Cleverjoe
Nov 5, 2013 09:22 AM
LundRover
Nov 21, 2011 09:02 PM
KBW
May 23, 2010 03:35 PM
