Sponsored by: CARiD
Major Help Needed - Engine Want Start
Old Feb 21, 2008 | 05:26 PM
auagd08's Avatar
Default Major Help Needed - Engine Want Start
I bought a 03 Land Rover Discovery about 2 hours ago. I was sitting inside the car trying to learn about everything and I think somehow I caused the car to go into lock down. Nothing works. The battery does not nothing, the lights do nothing, etc. I am an hour away from the closest retailer. Any help would be appreciated!! I am desperate!
Thanks in advance!
Old Feb 21, 2008 | 07:05 PM
WolfPack's Avatar
Default RE: Major Help Needed - Engine Want Start
Since no one's responded yet, I'll try and help ya out. I drive a Range Rover, but some of the systems are the same so here goes!
The Range has whats called Superlock, which is a complete lockdown, and pretty much deadbolts the doors shut. It cuts out all electrical, but then again if youre in the vehicle you would trigger the interior sound/motion alarm.
Try unlocking the door manually with the key, and go to the unlock side twice in a row. If still nothing happens, then there's probably another issue.
Just to check, did you make sure both battery connections are solidly connected, and how old is the battery? It is possible if the truck was sitting on the lot for a while, stuff corroded and what not then failed on the drive home!
Good luck, and I hope this helps!
Old Feb 21, 2008 | 07:25 PM
auagd08's Avatar
I got it taken care of!! Thanks so much! It was the battery!
Old Feb 21, 2008 | 07:27 PM
WolfPack's Avatar
Glad to hear it! Enjoy your new Land Rover
Old Feb 21, 2008 | 08:11 PM
okdiscoguy's Avatar
Post in the Discovery section next time and you will get a faster response....
Welcome to the forums.
RROJ
Jul 15, 2011 07:03 PM
Loveoffroading
Jan 21, 2011 01:46 PM
mandythelandy
Defender
Dec 26, 2008 04:33 AM
P_vannortwick
Sep 3, 2007 08:55 PM
CMARCH702
Sep 21, 2006 04:09 PM
