Sponsored by: CARiD
Manual Shifting
Old Apr 10, 2006 | 05:43 PM
samsly's Avatar
Default Manual Shifting
this morning I changed a couple of fuses in the car, they were not bad but they were the wrong amp size. Afterwords the car has been stuck in manual mode.. (I think its manual mode) shows me the GEAR error on the screen and has not been able to switch to fourth gear. When it shifts gear the car rocks as if it was a manual ride.. but remains 3rd gear and would not shift any higher... anyone has any ideas what could be the cause and how to repair it... I was told to remove the fuse in the F11 spot, which I did, but car remains the same way... how do I get it back to normal? :-(~~
Old Apr 10, 2006 | 11:08 PM
Bait's Avatar
Default RE: Manual Shifting
Huh? It didn't do that before the fuse change? It shifts fine till forth gear then what?
Old Apr 11, 2006 | 03:21 AM
samsly's Avatar
it worked fine prior to the fuse being added there. After I added the fuse it switched to Manual, now has not changed back.... [:@]
Old Apr 11, 2006 | 04:58 PM
samsly's Avatar
Any other ideas?????????
Old Apr 11, 2006 | 11:37 PM
Bait's Avatar
Yes, stop posting the same issue twice! https://landroverforums.com/m_8704/m...y_/tm.htm#8779
You need a new transfer box ecu and it has nothing to do with fuses.
Old Apr 11, 2006 | 11:49 PM
samsly's Avatar
I posted it in two different sections, I realize it takes a while for anyone in the Range Rover to respond so I posted it the general tech section. No need to blow a fuse man!! [:@] And that was NOT the same issue as before.. geez.. I'm out of this Forum...
But thnx for the info!
Old Apr 13, 2006 | 01:36 AM
Bait's Avatar
ORIGINAL: samsly
thnx for the info!
Your welcome and good bye.
ranger
Jan 14, 2007 01:05 PM
aBs0lut30
Jul 5, 2006 10:43 PM
Jawbox
May 12, 2006 10:26 AM
JasonKramer33
May 2, 2006 05:30 PM
adowgiert
Aug 27, 2005 04:53 PM
