Sponsored by: CARiD
Marant23
Old Jul 8, 2017 | 08:42 AM
MARANT23's Avatar
8th Gear
Default Marant23
2008 LR2, 83000 miles, replaced differential, Installed 4 new tires, replaced 2 rear weel bearing, changed the front weel break pads, installed new battery and alternator.
now I have a mesage, transmission fault tracción reduced and that dsc is off and terrain response system is faulty.
Can any one outhere tell what's going one please, thank you
Old Aug 3, 2017 | 07:04 PM
MARANT23's Avatar
8th Gear
Default Haldex
After all the repairs 2 find out ware the rubbing sound was coming from whenever I turn the steering wheel The technician U did the work on the car disconnected the connector 2 the Haldex unit, the rubbing sound is gone but the messages are still dare, Seams like by disconnecting de Haldex it set the car in 2WD.
Then is the pump on the Haldex bad or the entire Haldex is bad, that is what I need to find out
