Sponsored by: CARiD
mr
Old May 9, 2016 | 01:37 PM
johan snyman's Avatar
Default mr
Want to find out where the speedo sencor is on a disco 2 2002 td5 is pls?
Old May 10, 2016 | 04:16 AM
loanrangie's Avatar
D2 uses a front wheel ABS sensor to send data to SLABS unit for speedometer, i guess you arent in the US ?
Old May 10, 2016 | 05:43 AM
number9's Avatar
Here's some info from the WM.
The SLABS ECU continually calculates vehicle speed using the wheel speed inputs from all four ABS sensors. The
calculated vehicle speed is then used as a reference against which individual wheel speeds are monitored for
unacceptable acceleration or deceleration.
File Type: pdf
Old May 10, 2016 | 01:29 PM
Default Speedo sencor location
Thanx a mil no im from Johannesburg South Africa my e-mail adress is sticksharley@gmail.com!
Old May 12, 2016 | 05:54 AM
loanrangie's Avatar
It reads all 4 but you only need 1 sensor to get the system to work, a mate has a TD5 in his D1 that is cut down to a ute (pickup ).
