Sponsored by: CARiD
my blinker is blinking fast. can i fix it?
Old Jan 24, 2015 | 12:49 AM
dusty1's Avatar
Default my blinker is blinking fast. can i fix it?
so on early d2, I have replaced the rear bumper and wanted to keep.lights down there.
wired up some led trailer lights. all is working fine........except my truck thinks I don't have rear blinkers. is there something I can do to make it blink *......*......*.....* instead of *.*.*.*
I can live with it and I have, but if its a simple fix.....I would like to get it back to normal
what can I do?
Old Jan 24, 2015 | 06:29 AM
lordmorpheus's Avatar
Sounds like you need some inline resistors for your LED lights. The increased resistance will trick your vehicle into thinking you have normal bulbs. They are widely available. The auto parts store I work at sells them in our LED bulb area.
Amazon.com: Putco 230004C LED Light Bulb Load Resistor Kit: Automotive Amazon.com: Putco 230004C LED Light Bulb Load Resistor Kit: Automotive
Old Jan 24, 2015 | 08:13 AM
dusty1's Avatar
On it
Old Jan 24, 2015 | 09:10 AM
fishEH's Avatar
I think this will work on a D2 as well. All you need is an LED flasher and some pigtails.
Blinker Tech - DiscoWeb
Old Jan 24, 2015 | 10:35 AM
dusty1's Avatar
that seems an easy deal.....swap a relay
Old Apr 13, 2015 | 12:00 PM
TOM R's Avatar
IS THERE A HD FLASHER THAT PLUGS IN WITHOUT THE PIGTAIL SETUP? sorry caps on
Old Apr 13, 2015 | 12:09 PM
fishEH's Avatar
No clue. If you find a plug n' play option post up. The pigtail isn't hard to make but getting rid of it altogether would be even easier.
Old Apr 13, 2015 | 12:18 PM
justryan's Avatar
It normally speeds up when one of the indicator bulbs are blown.... check the others first
Old Apr 13, 2015 | 01:33 PM
TOM R's Avatar
I do not have a bad bulb,installed some led
Old Jun 3, 2015 | 03:26 PM
TOM R's Avatar
was killing time and came across how to instructions on removing the dead lamp circuit from a flasher, this was for jeep and mazda etc.
ours looks different inside BUT i am sure there is a smart person here that can figure out what to cut inside the lucas flasher to kill that circuit, then no more fast flash with led or ep26 with pigtails
