Sponsored by: CARiD
Mysteriously Not Starting
Old Mar 15, 2011 | 12:58 PM
dcoston's Avatar
Default Mysteriously Not Starting
I need some advice. My Disco II 2000 came to a stop and the engine turned off. My mechanic is looking but can't find anything wrong. The engine turns but won't turn over. Is there something typical I can tell him to look for?
Old Mar 16, 2011 | 06:14 AM
DMOODYDISCOII's Avatar
7th Gear
Same problems with my 04 disco ii. I have replaced the maf and fuel pump, but no luck yet. It sometimes will start if the engine is cold, but only runs for about 20-35 mins before shutting its self off. I'll keep you posted if I find it out, you do the same.
Old Mar 16, 2011 | 12:51 PM
groundandpound's Avatar
I would start with the usual suspects - make sure you are getting 37psi to the fuel rail, make sure there is spark etc....
Old Mar 29, 2011 | 06:16 AM
7th Gear
Ok replaced the crank sensor $60 at autozone hope this helps.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
readdiscovery
Jul 7, 2006 05:23 PM
nick
Freelander
Mar 14, 2006 04:41 PM
pants
Oct 19, 2005 12:47 AM
nick
Jul 17, 2005 02:04 PM
