Need Help!
I flushed my coolant this afternoon to install a new thermostat as well as fresh coolant.
I filled up the new coolant into the reservoir after everything was flushed. After filling some water/antifreeze is pouring out the back side of the motor. It had got dark and i can not tell where it is coming from.
Any help is greatly appreciated.
Chandler
Chandler
I suppose it's possible that the pressure in a flush could sometimes be high enough to pop out a freeze plug on the back side of the motor, but I'd examine the heater hoses and throttle body heater plumbing closely, first.
It may be the heater hoses check the two hoses than run along the top of the passenger valve cover and are connected to two ports on the passenger side firewall you may have a loose or bad hose, if it is on the driver side check the throttle body heater located between the throttle body and valve cover on the driver side.
Through closer inspection it looks to be the intake manifold gasket. I got a new one from Atlantic British.
I also picked up valve cover gaskets while i have everything apart.
