Sponsored by: CARiD
Need help identifing relay
Old May 16, 2019 | 04:22 PM
User966's Avatar
7th Gear
Default Need help identifing relay
I have a 98 Discovery one Land Rover. Someone has run a wire from the battery to a relay that is in the kick panel on the left side. Can anybody tell me what this relay goes to. Coming from the rear it is the first relay. There are two Violet wires that have been cut and a wire from the battery put in it's place. There are two other wires. A Violet/orange and Violet/green running to the same relay. I'm asking because I have a drain on the battery. It drains in about 4 hours. The battery was charged and held the charge for several days before I put it in the truck.
Old May 16, 2019 | 10:02 PM
OverRover's Avatar
Here's what RAVE has for the LH Footwell Relays.
Maybe the horn relay
Good Luck!
Old May 17, 2019 | 04:43 PM
User966's Avatar
7th Gear
Default Thank you
Thank you for that answer. So, is it ok for the horn to stay hot at all times. That means they bypassed the under hood relay. They put an inline fuse in it. I disconnected that wire and my battery didn't drain last night. I'll check in a little bit to see if the horn works.
Cigarhuntr
Apr 10, 2021 09:02 AM
lr4_2012
LR4
Jun 5, 2019 03:13 PM
xathor
Jul 28, 2017 07:40 PM
dobe1canobe
Jan 26, 2015 12:29 PM
qdriskell
Sep 15, 2011 06:04 PM
