Need help ID'ing some Plugs
2003 Discovery 2
i found a plug with nothing connected. it's on the passenger/RH side wheel well. couldn't find any cables around it that weren't connected.
there is one ont he drivers side as well and appears to be connected to something on the brakes.
any help is would be great.
thanks
jon
thanks
jon
no lights or codes. but, the breaks haven't acted normal since i bought it. it sometimes feels like i have HORRIBLY warped rotors, and sometimes feels fine. i'll go out and inspect a little closer.
What lights come on when you crank up the truck at the initial 3 second bulb test? See attached page from owners manual, if you don't have the whole set of manuals, free download below, called the RAVE.
brake light comes on, then extinguishes. works with the ebrake also.
i traced out the wire that on the drivers side goes to the plug. on the passenger side it comes up into the engine bay, then goes into the fire wall. is there a chance this is just extra? can any other '03 base model owners take a look?
yep, ABS comes on, then off after 3 seconds also.
my other thought would be it had a problem at one time and the PO bypassed the wiring harness. whoever owned it knew a bit about rovers, as all the "do this when you buy it" stuff had been done already when i bought it, ie. front driveshaft.
thanks
jon
thanks
jon
07Bossman
Mar 29, 2015 09:10 AM
NEW2ROVERREPAIR
Jan 8, 2009 04:00 PM
