Need help please
Old 03-24-2015, 08:46 PM
Received 1,512 Likes on 1,239 Posts
So truck was overheating and probably had a air pocket in the cooling system from lost fluid. Shown by the loss of heat.
Top off and drive it watching a temp gauge that doesn't move from middle until it's already overheated, rise towards the red. Then the gauge drops to Cold just before you shut down. The sender probably went to a temp that was so outside of spec the system faulted to Cold.
Odds are the fuel pump didn't fail at the same time. Maybe melted the injector o-rings.
I hope I'm wrong but I would put odds on the motor is cooked. Never drive these when there is a cooling system problem, 9/10 times it's fatal to the motor
Old 04-01-2015, 03:49 PM
ChrisandEmily Campbell's Avatar
6th Gear
Thanks for the help guys. So I ran a diagnostic and everything checks out fine (minus the o2 sensors). I checked the schrader valve and there is fuel. It doesn't have pressure just kind of pours out, but then again the motor isn't running. Its still turning over so next I will check the spark plugs and the starter. I don't think that the motor is dead. It is giving me no signs that its cooked.
Paul Aspen
11-04-2013 02:10 PM
tarpon66
07-27-2011 12:38 PM
sawadeh
07-02-2011 08:10 PM
brad
01-03-2005 07:10 AM
Quick Reply: Need help please
