New XYZ switch installed not working please help
Hi everyone I was having the gear box switch code P0705 with my 05 land rover range rover so bought a new one and installed today now transmission is stuck on 4 th gear the light on shifter **** is conflicting the one on the dash when the **** shows park the dash shows Neutral don't know what went wrong. When I start the car I see N on the dash when the P is actually selected so when I start selecting the gear I will see D in the dash and then no more light on the dash and check engine light comes on also engine fail safe mode prog. Has anyone changed the XYZ switch b4 please help. I also put the old switch back but the range no longer start with the old switch
thank you
thank you
aarongregor
01-10-2024 12:52 PM
Toran
09-13-2015 11:03 AM
