No sound from Radio
No sound from Radio
I just got an '07 LR3 (brand new leftover). It has 60 total miles.
The radio stopped working. That is, it's on, but there's no sound AT ALL. I can switch between AM/FM - no sound. CD the CD's don't advance. That is they don't spin. I can tell because the conter stays at zero. I can turn the volume all the way up/down, balance, bass, treble, fader, subwoofer, etc. NO SOUND
I turned it off for a 10 mins, started it up and the radio worked. Just got back from the gym a while ago. The radio worked on the way there, but not on the way back SAME PROBLEM. I turned it off. Set the alarm. Waited one minute, but no radio. . . . . . . .
I searched the forum and noted that a guy coming back from some football game had the same problem. The answer there is that it needed a software update and there is a Tech Bulletin B034 &B036 on the subject.
Is the Tech Bulletin the answer? Does anyone know what gives?
It's under warranty and it will go back, but I want the skinny from members so I don't get the run-around . . . . . THANK YOU ALL!!!!!!!
mvjimenez
06-12-2010 10:25 AM
fp360spidr
01-26-2009 08:44 PM
