noise underneath
RE: noise underneath
it sounds like its normal. the transfer case is completely gear driven, and loading/ unloading the drivetrain will cause a clunk in the gears. as long as it is a deep pitched somewhat heavy clunk, its fine. if it sounds more hollow and metalic, it might be the u-joints in your hookes joint, as mentioned above. however those u-joints starting to fail will always cause a strong body vibration under accel at about 30 mph.
[/align]
if you go the route of replacing the u-joints, be very careful of the center piviot bearing inside the hookes joint (double u-joint) it can be very hard to set this back up right, ive seen several seasoned techs have cars come back a week later and need a whole prop shaft cus it wasnt right.
[/align]
mupmanyu
03-07-2011 06:42 PM
