Sponsored by: CARiD
Oil
Old May 5, 2008 | 02:34 PM
DiscoSam2's Avatar
Default Oil
I was wondering if I over fill motor by 1/2 quart if it will do any damage to 4.0 motor,I don't think it is over filled enough to spin a bearing ,but as testy as mine is I figured I'd get a 2nd opinion
Old May 5, 2008 | 05:49 PM
Default RE: Oil
If you are 1/2 quart over the full mark, I would drain a little off.
Old May 11, 2008 | 04:54 AM
Bartell's Avatar
Default RE: Oil
ORIGINAL: DiscoSam2
No. The oiling system on the vehicle is a high flow, not high a pressure system. Extra oil (within reason) will not effect anything but the oil temperature (it will be lower). Racers have being putting a quart over for years. We use 1/2 quart over regularly.
James
Old May 11, 2008 | 10:23 AM
Default RE: Oil
For the record, overfilling an engine can cause seal problems, be it for the engine or tranny.
Old May 13, 2008 | 01:20 AM
Bartell's Avatar
Default RE: Oil
ORIGINAL: Disco Mike
No it can't with this engine Mike. You are thnking of other engines that rely on high oil pressure. We can't be calming people when they first see the remarkably standard low pressure on a 1995 LR (compared to other vehicles) and then tell them they are going to blow seals because of high pressure when they add an extra 1/2 pint.
Seals can only be affected if the oil pressure goes up. As I said this is a volume not a pressure system so no damage to seals can occur and you will find oil pressure completely unaffected by adding a bit extra. Racers like us have running these engines over "full" (up to a pint over) oil for decades without a problem. It started in the days of the first small sumps. More oil less heat. That is why the last of the sumps held 1.5 pints more than the first.
Of course, if it makes one feel more comfortable, one can try draining a 1/2 pint of motor oil to bring the level below the full mark. It simply doesn't make a real difference beyond increasing the oil heat a bit.
James
Old May 13, 2008 | 09:04 PM
roverguy7's Avatar
Default RE: Oil
youre both kind of right here... too much oil will cause a drop in oil pressure due to airration caused by the crank spining in the sump too much, however, yeah, this engine is pretty forgiving, half a quart will not do any damage
Memphy03
Aug 3, 2009 08:58 AM
javoli002
Jul 16, 2009 01:24 PM
jkeving
Jan 19, 2008 08:06 PM
shagybruce
Feb 8, 2007 02:52 PM
