Oil
I was wondering if I over fill motor by 1/2 quart if it will do any damage to 4.0 motor,I don't think it is over filled enough to spin a bearing ,but as testy as mine is I figured I'd get a 2nd opinion
ORIGINAL: DiscoSam2
James
ORIGINAL: Disco Mike
For the record, overfilling an engine can cause seal problems, be it for the engine or tranny.
Seals can only be affected if the oil pressure goes up. As I said this is a volume not a pressure system so no damage to seals can occur and you will find oil pressure completely unaffected by adding a bit extra. Racers like us have running these engines over "full" (up to a pint over) oil for decades without a problem. It started in the days of the first small sumps. More oil less heat. That is why the last of the sumps held 1.5 pints more than the first.
Of course, if it makes one feel more comfortable, one can try draining a 1/2 pint of motor oil to bring the level below the full mark. It simply doesn't make a real difference beyond increasing the oil heat a bit.
James
youre both kind of right here... too much oil will cause a drop in oil pressure due to airration caused by the crank spining in the sump too much, however, yeah, this engine is pretty forgiving, half a quart will not do any damage
disco12
Mar 7, 2006 01:10 AM
