Oil cleanup
I'm in the process of replacing my water pump and t-stat and the front of the block is filthy (covered in oil). Obviously I am going to fix the source of the oil (which I believe is the VC gasket) but I'm curious about the best way to clean this up. I was thinking of spraying Simple Green over the front of the block with the belt off and then rinsing with water. Can anybody think of any reason this would be harmful?
camaroz1985
12-09-2009 11:01 AM
disco12
03-07-2006 01:10 AM
