Sponsored by: CARiD
Oil cleanup
Old Oct 20, 2014 | 09:28 PM
Drubie22's Avatar
Default Oil cleanup
I'm in the process of replacing my water pump and t-stat and the front of the block is filthy (covered in oil). Obviously I am going to fix the source of the oil (which I believe is the VC gasket) but I'm curious about the best way to clean this up. I was thinking of spraying Simple Green over the front of the block with the belt off and then rinsing with water. Can anybody think of any reason this would be harmful?
Old Oct 21, 2014 | 07:47 AM
dusty1's Avatar
Not harmful
I usually hit it with degreaser, scrub off what I can and then pressure spray it.
Old Oct 21, 2014 | 09:14 AM
drowssap's Avatar
it will take a lot of simple green you would be better of with degreaser or oven cleaner
Old Oct 21, 2014 | 10:28 AM
Drubie22's Avatar
Are there any parts I should avoid hitting with the degreaser? Like the pulleys or hoses?
Old Oct 21, 2014 | 12:27 PM
drowssap's Avatar
spray away, if the belt is off
Old Oct 22, 2014 | 10:19 AM
abran's Avatar
I like brake cleaner and a rag.
Old Oct 22, 2014 | 12:12 PM
Scout_Beagle's Avatar
I've had good results with "Purple Power" de-greaser I got at the local auto parts store.
camaroz1985
Dec 9, 2009 11:01 AM
Memphy03
Aug 3, 2009 08:58 AM
jkeving
Jan 19, 2008 08:06 PM
shagybruce
Feb 8, 2007 02:52 PM
