Oil filter question
  #21
Old 08-14-2015, 05:32 AM
drowssap's Avatar
probably another wonderful video from "BOB the oil guy"
  #22
Old 08-19-2015, 06:18 AM
MM3846's Avatar
Originally Posted by Disco Mike
For those who are wanting the best oil filter and results, you might want to do a Google search for the last oil filter performance tests that were done last year.
Yes, bigger filters with more capacity help but comparisons do show a filtering quality difference.
For me, I would rather buy the best for the little extra protection to go with your better quality oils.
Just a thought.
Originally Posted by justryan
The best oil filter after the manufacture spec ....is the closest one to manufacture spec...
Oil filters may look the same on the outside ... but on the inside it varies a lot ....
some filters have the pressure valve inside , some are just a free flow , look inside the big centre hole of the original OEM One ... and not to forget the weight ... then look inside the substitutes... see if it looks empty ? it may just be regular paper element ... ( you don't want that one ) the good filters have valves to regulate pressure ... and is heavier...
be careful ....putting million dollar oil in your engine is not going to save it from wear , if its not filtered properly ...
Yea, yea. How about doing some research on that before just spewing up generalizations and guesses?
Part Number: 51515
UPC Number: 765809515154
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.18 (132)*
Outer Diameter Top: 3.66 (93)*
Outer Diameter Bottom: Closed:
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 290
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Operating Temp. (min): 0
Operating Temp. (max): 0
Capacity: 0
Filter Area: 0
Part Number: 51068
UPC Number: 765809510685
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338 (110)*
Thread Size: 3/4-16
Burst Pressure-PSI: 275
Capacity: 0
Filter Area: 0
The only difference besides size, is that the larger filter can take an extra 15 PSI before blowing up.
eitydeuce
01-02-2014 09:51 PM
MrFlea1
02-03-2012 01:36 PM
moncton_vw
09-24-2011 07:19 PM
flyingasics
05-21-2007 09:00 PM
fuel
12-13-2004 04:49 PM
Quick Reply: Oil filter question
