Overheating 2004 D2 after distance
I bought a 2004 Discovery with 75k and started driving it back home. Traveled about 90 miles and stopped for fuel. Getting back on the road as i accelerated onto the interstate the temp started to rise. Pulled off and found the coolant level low. Replaced about half gallon and drove another 200 miles on the interstate without trouble. Stopped for the night and replaced about 1/2 gal in the morning before heading home. Traveled another 200 miles before siting in traffic just off the interstate and had another temp rise and a need for another half gallon of coolant. I see no exterior leaks. Bought a replacement thermostat hoping that is the problem but where is the coolant going? So i suppose I am burning it off thru a leak in the head gasket? Haven't replace the thermo yet and also have Blue Devil Head gaskets fluid to try. I am not a real mechanic and am afraid to do anything without experienced advice. HELP!
Check the oil level and check the oil clarity, milk chocolate means coolant is in the crankcase. White steam that smells like coolant coming from the exhaust would be combustion indicator. How did the motor sound while running, missing? Spark plugs that are steam cleaned have a white insulator like brand new plugs. Compression test on motor and a cooling system pressure test will tell if and where.
NYChasNOtrails
05-12-2008 11:48 AM
