Overheating but low temp on gauge
Old 10-07-2006 | 03:01 PM
BMWLR's Avatar
Default RE: Overheating but low temp on gauge
ORIGINAL: dmonares
Radiator caps are designed to allow overflow depending on the pressure in your cooling system.
Got it... thanks
Still with this problem!
Old 10-08-2006 | 08:21 PM
dmonares's Avatar
Have you checked to see if you have any mud or debris between the A/C condensor and the Radiator?
If it is free from debris your only answer to this situation is your Radiator is shot and it either needs to be replaced or rodded.
Old 10-10-2006 | 03:02 AM
BMWLR's Avatar
ORIGINAL: dmonares
No debris between the condensor and the radiator!
Although I flushed the radiator twice, I now bought a radiator cleaner. I will do it during next weekend and see what happens!
Old 10-10-2006 | 02:27 PM
I just noticed this post and saw it was recommended that you use a coolant stop leak, and I have to tell you taht is one of the worst things yiu can do to an alloy engine, you will land up plugging up water out lets, the heater, your radiator and the list goes on.
Mike
Old 11-13-2006 | 06:14 AM
land.mike@gmail.com's Avatar
Did this ever get resolved, as this seems to be common place with the BMR Landys
Old 11-14-2006 | 12:10 AM
BMWLR's Avatar
ORIGINAL: land.mike@gmail.com
Nope... I don't use this truck so I have not put enough effort in to it.
The fan was replaced, thermostat replaced, full rad flush and purged, all hoses checked... problem peristed!
As explained before, the truck can be used for small trips with out problems so... I maight sell the truck like that.
I have two other toys and I decided that I don't have time for a third tou to play with!
GoingPlaces
06-15-2015 09:25 AM
Rover_Hokie
02-02-2014 03:52 PM
silverman.jerry@gmail.com
02-01-2012 06:03 PM
collin Barrows
08-08-2011 09:33 PM
ozmoto
09-10-2005 01:07 AM
Quick Reply: Overheating but low temp on gauge
