P1316
It is a misfire code caused by excessive emissons.
How many miles on the truck, what octane gas are you running and what has been done to it tune up wise in the last year or so?
Mike- Went with the bosch plugs I had replaced the wires earlier when I removed the old plugs I noticed all plugs had fired but one replaced that plug wire with one I had from an old set problem solved, Truck runs better than ever thanks for the suggestions.
wease206
Dec 29, 2009 11:57 AM
