Sponsored by: CARiD
performance boost for disco 2001
Old Oct 3, 2005 | 04:53 AM
Randy Lover's Avatar
Default performance boost for disco 2001
when i was out yesterday i came across a product by the compnay car plan.
the bottle said
empty all the contents of this bottle into the fuel tank of a diesle vehicle
it said this would happen
increase BHP by 10%
lower fuel consupmtion
lower fuel emisions
does anyone know if this is anygood or just a lame scam ?
thanks
Old Oct 3, 2005 | 10:27 AM
Landzu's Avatar
Default RE: performance boost for disco 2001
The bottle is a cetane boost also I bet.
If you have never run any injector cleaner it may help
up to what point who knows.
The 10 bhp is worst case.
I have a VW TDI with a Ups chip large injectors and use a cetane booster ever time I full up.
The diesel here in the U.S. leaves a bit to desire.
Hope that helps. Mike
Old Oct 3, 2005 | 04:23 PM
yeh thanks
its definstly cetane
what do you mean "10bhp is the worst bit"
and by the way does it make the car more responsive or faster ?
Old Oct 4, 2005 | 09:58 AM
Landzu's Avatar
By worst bit, if the injectors are 1/2 pluged you have carbon build up just a
mess someone that has not taken care of anything only 1% is this bad.
Some of the additives make my car smoke less , some make it feel
faster. I can tell when I get higher cetane diesel it makes everthing
much smoother and faster.
Also most additives have a injector pump lube.
You may have to change your fuel filter after you try it
some time there is a varnish build it will clean out of the tank.
Only bad diesel will have a little build up, I think you have good
diesel. We have cheap diesel, cost and quality .
Mike
Gr8lite
Aug 2, 2010 07:01 PM
desertdude
Oct 6, 2008 08:49 PM
nynole
Sep 9, 2008 06:24 PM
TD5BRAD
Aug 12, 2008 09:54 AM
meyersd
Aug 14, 2006 12:32 PM
