Sponsored by: CARiD
wont start
Old Sep 30, 2005 | 11:28 PM
redmond's Avatar
4wd High
Default wont start
i was driving a long time vechile just stop running it has 148000 miles i love this truck towed it back home did normal check found no spark from coil replaced still no spark now i think it might have been the amplifier module all along please help
Old Sep 30, 2005 | 11:29 PM
redmond's Avatar
4wd High
Default RE: wont start
vechile has no spark from coil after replaced died on road think it may be amplifier module has 148000 miles
Old Oct 1, 2005 | 11:52 PM
Bait's Avatar
You don't list year and model ? But since you say it has a coil, it must be a disco I, classic or early ( pre 96') Defender. Am I correct ?
No spark, try this. Turn key on. Use a test light ( not a meter ) and check if both sides of the coil have power. Then have someone crank the engine whilst checking the same thing. One side of the coil you should see a faint pulsing of your test light. If you don't see the pulsing, 90 % of the time it is the ignition module that is bad. The newer type modules use a three pin weather pack style connector. The old type use a rubber push on two pin spade connector. If you have the newer type, chances are it is not bad. They are robust. Let us know. Good luck !
Old Oct 2, 2005 | 12:33 AM
bonnettoboot's Avatar
As has been said it is likely the Ignition module, in case you don't know it is on the side of the distributor.
________
cannabis collective
Old Oct 4, 2005 | 04:53 PM
anonimaus's Avatar
If he has the old ones, could also be a problem with the wires/spade connections getting old. I had to snip mine and put new connectors on it. Check the coil first, as suggested. If you aren't getting power, check the wires and connectors.
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
